Sign construction advice
Circleville Signs
OK - Here's my dilema - and I know there is probably an easy answer, however i've not ever tried this before with Polymetal/Dibond.
I've got a sign completely made out of 6mm Polymetal. It is 3'x6', or at least the panel is.
This panel has a full digital print piece laid down on it. I need to attach some routed shapes to this face, that are also cut from 6mm Polymetal.
Here's the kicker - they need to be flush, AND I can' have bolts sticking out of the back of the sign, as it is single sided, eye level post mounted.
Oh, yeah - and one layer of the routed shapes sits on top of another one, but is larger - so I'm going to have to anchor it with some type of spacers, I'm thinking?
Will gorilla glue work for this? I'm worried to use silicone because I won't be able to get things flush.
Any suggestions are appreciated!
J Hill Designs
I would probably use laminating adhesive sheets for that...my brand of choice is mactac IB-2107 comes 17"x22" sheets
silicone done correctly would be flush...just weigh it down
J Hill Designs
I would say so...It's full contact across the entire surface...I can test with a heavier than 3 lbs setup RQ if you want...
how thick is your base piece and lettering?
i've stud mouted 1/8" to 1/8" before without having the studs sticking out either side... paired with adhesive of any kind, they'll never fall off.
J Hill Designs
OK approx 5lb - 1/8" aluminum sheet attached to dibond - not only does it not fall off, I am having a hard time releasing it with force
as for exterior, I can only imagine yes since its a PE core with acrylic adhesive...water/solvent resistant
J Hill Designs
most VHB is too thick to not see a visible offset from the surface..and the thin stuff (I have found) doesnt quite work that well
Billct2
What about a nest rout were the panels will be placed? Then they could be glued/silconed into the inset.
