SignGo software?
Discussion in 'General Software' started by VINYLVISION, May 24, 2006.
  1. VINYLVISION
    VINYLVISION Member
    67
    Has anybody heard of SignGo,if is good to start with,I have the Master xy300p and came with flexi starter.
    I need a little more options like text arc,shadow and drop shadow so I can get my business started, (feet wet) Can anybody help ,:thankyou:
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    Yes,, i tested it .. its adequate..
    But Corel draw and cocut pro is a nicer choice..
  3. VINYLVISION
    VINYLVISION Member
    67
    Does the Corel draw and cocut pro have a driver for the master xy300p?
  4. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    cocut has a generic HPGL driver. IF yoru cutter follows the standard HPGL specs then you should have no problems. However, Some off brand cutters are using reversed HPGL or some other unknown variant of such.
    www.cocut.com and have a looksee..
  5. Cadmn
    Cadmn Very Active Member
    2,859
    corel will gut to HPGL cutters
  6. VINYLVISION
    VINYLVISION Member
    67
    Great I will look into that,
  7. Bradster941
    Bradster941 Very Active Member
    2,190
    Here is a link to SignGo http://www.signgo.com/index.html
    VinylVision, you might want to contact a member here called BigDawg, (Stacy) as I think she has your make of plotter and is using Corel.
