The probelm I am presented with is whenever I print from SL 9.1 I am getting this what looks to be banding. But when I print the same file from Corel through Flexi it prints perfectly. I have tried setting the heat platens to the exact temps as Flexi and still the same problem. I have done a head check and its 100%. I did run another print with the hood open and noticed that its not the print head causing my problems. On the front left of the printer carriage there is the electric eye for checking the with of the paper. It seems when that passes over the print it is dragging causing the lines but when I print from Flexi it prints fine. I am thinking its the heat but not sure. Keep in mind I have only had the printer for 3 months so still in the learning stages. The problem is obviously the SL settings but I have had no luck. Any help is appreciated.
Thanks,
RC
Thanks,
RC
