Solvent ss2 inks used in home?
SightLine
Could be a fried head, bad cable, damaged slider board, or damaged main board. Hope you did not get any ink/solvent on the top of the heads or let any run down the ribbon cables. Also critical, let the machine sit TOTALLY unplugged for several minutes to make sure any capacitors on the boards are discharged before plugging/unplugging any head or other cables.
Did you even bother to search?
http://www.signs101.com/forums/showthread.php?108044
http://www.signs101.com/forums/showthread.php?42265
http://www.signs101.com/forums/showthread.php?87152
http://www.signs101.com/forums/showthread.php?94733
http://www.signs101.com/forums/showthread.php?92430
http://www.signs101.com/forums/showthread.php?87064
http://www.signs101.com/forums/showthread.php?85924
http://www.signs101.com/forums/showthread.php?71743
