Source for stencil?
Discussion in 'Product and Supplier Referrals' started by Andy D, Jul 28, 2020.
  1. Andy D
    Andy D Very Active Member
    2,523
    492
    83
    Oct 20, 2014
    Hattiesburg, MS
    I'm trying to help a customer out, he needs a basic cardstock, cardboard, or plastic spray paint stencil & doesn't want to mess with spray mask, can anyone recommend a vendor?
  2. Notarealsignguy
    Notarealsignguy Very Active Member
    1,557
    449
    83
    Feb 20, 2020
    Florida
    I get asked for this a lot. Let me know what you figure out if nobody replies. I thought about setting up a cut file and having s365 do it in pvc or something?
  3. JBurton
    JBurton Signtologist
    2,200
    493
    83
    Sep 28, 2017
    Arkansas
    How many?
    I've double cut 7725 vinyl before, so it goes through the plastic backing. Makes a fine stencil, lays flat.
    • Informative Informative x 1
    • I Appreciate You I Appreciate You x 1
  4. James Burke
    James Burke Being a grandpa is more fun than working
    3,536
    522
    113
    Jan 2, 2010
    Mitten State
  5. Andy D
    2,523
    492
    83
    Oct 20, 2014
    Hattiesburg, MS
    Thanks for the suggestion, but honestly it's something I don't want to mess with, I will order it but I don't want to start making them.
  6. LarryB
    LarryB Member
    284
    20
    18
    Dec 3, 2006
    Webster, Texas
    Find someone with a router cutter. We cut them out of 3mm pvc
  7. Andy D
    2,523
    492
    83
    Oct 20, 2014
    Hattiesburg, MS
    I'm not sure what that is. Have you seen where people have a modification that turns your plotter into a flatbed cutter?
  8. CanuckSigns
    CanuckSigns Very Active Member
    3,627
    486
    83
    Nov 11, 2008
    Ontario
    We make tons of stencils on our laser engraver, cut them out of mylar sheeting, or oilboard, depending on how long it's intended use is.
    Oil board can probably be cut with a standard plotter with multiple passes.
  9. Notarealsignguy
    1,557
    449
    83
    Feb 20, 2020
    Florida
    I have not but that would be interesting. I have wondered why hybrid flatbeds are so much more money than roll printers. It seems like a little more vacuum and beefier drive system is the main difference but a lot more $$$$.
    I meant use Signs365, they offer printing and contour cutting pvc and other materials. A stencil should be just the same minus the print?
  10. Greg Kelm
    Greg Kelm Member
    107
    15
    18
    Aug 20, 2019
    Rancho Cucamonga
    how big of a stencil?
  11. Sindex Printing
    Sindex Printing Member
    161
    40
    28
    Nov 17, 2018
    Sparks
    I laser cut them for customers out of 16 point card stock, 14mil synthetic sheets. I have had a few customers ask for thin acrylic and corregated sheets
