Thanks for the replies guys.
Tried some trouble shooting this morning. The cut is now off on a file exported out of SL8. I'm kind of at a loss.
Sorry, I should have prefaced that the artwork is over sized, therefore I'm working with tiling. The artwork is a star, so we are printing the tip and then the rest of the star...
So like I said, I tried the print/cut alignment test directly from the sp-300. It was dead on... I scaled down the star to 3" x 3" and it cut it perfect...
I have a feeling it's a tiling setting.
cdiesel wrote:
Is <center on media> selected? This is a common cause of this problem. I assume that you verified that the cutpath is in the correct position in the print file? When you say that it is "way off", is it shifted entirely in one direction, or does it start off okay and then get worse?
Where is the <center on media> in Versa Works?
The cut path is dead nuts on both in Illy and SL8 with a .125" bleed...
It's way off in one direction (.25"). I played with some tiling settings and got it closer (.125") off now...
Side note: zoomed out in VW, it looks off in the same manner as it mis cuts.
Zoomed in super close the cut path is dead on.
