SP300v and windows 7
Discussion in 'Roland' started by Tony McD, Sep 1, 2010.
  1. Tony McD
    Tony McD Member
    458
    2
    18
    Sep 13, 2006
    Camdenton, Missouri
    I got a new windows 7 x64 computer in January.
    The last machine was running windows xp.
    When I wanted to print from corel draw to versaworks I just picked it from the printers list.
    My Versaworks has updated to version 4.0.1
    I have the original install disc version 2.0
    Here's my problem:
    Since installing these programs on the windows 7 machine, I have to export the file from corel, and then import the file into versaworks.
    While this works fine, I really liked being able to print to versaworks right from corel.
    The sp300v printer shows up in the "unspecified devices" section of the printers folder. In the device manager, there is a question mark next it.
    If I delete it....it comes back.
    Versaworks doesn't show up in the printers folder.
    If it was in there, it would probably show up in my corel printer list.
    Basically I want to print straight to versaworks from Corel without having to export files.
  2. CS-SignSupply
    CS-SignSupply Very Active Member
    During the install of VW, you should have been prompted to install the 300v Printer driver... if you choose no, what you describe is what happens.
    If it did not prompt you, the Windows 7 and VW 2.x could be the issue
    To solve the issue, you might need to contact Roland DGA to get an updated 4.x install DVD, then uninstall and reinstall.
  3. Tony McD
    Tony McD Member
    458
    2
    18
    Sep 13, 2006
    Camdenton, Missouri
    Thanks Bobby,
    I will order the version 4 dvd, and give that a try.
    That may very well be my problem.
  4. Tony McD
    Tony McD Member
    458
    2
    18
    Sep 13, 2006
    Camdenton, Missouri
    Bobby,
    I searched Roland's website and can only find a place to download the software...no place to order a dvd.
    Called the place I bought the machine from, and they don't have one either, and suggested contacting Roland.
    So, I have an e-mail sent off to roland about getting a dvd with the 4.0 software. Hope to hear back from them soon.
  5. amw
    amw Member
    when you load versaworks it asked if you wanted the driver loaded...say yes and it should work. we use win7 64 and have no trouble using our orig. cd that came with the printer.
  6. mtroup
    mtroup Member
    71
    Apr 4, 2010
    Arkansas
    You can order the DVD from Roland, call into tech support and give them your serial number.. They should have some in stock now as they were backordered a few weeks ago. I think it's $25.
