I also posted this on the Roland Forums, but it seems there is more activity here so I also posted it here. So I have a SP300v I was having some issues, Turns out the Printhead manifolds were crack, probably from me changing the dampers a few times from routine maintenance. So I changes the manifolds. I put the heads back in and started to print. As the printer was printing, it slowly stopped putting ink out until there was nothing. So I took it back apart and noticed that one of the head cables was not all the way pushed into the board. So I checked the F1/F2 fuses- one was blown, the other one was fine. Only the 1 head wasn't printing. So I took the board (and a spare board that I had with blown fuses on it) to the electronics shop and had them change the fuses. I put the board back in and neither head is printing. The Black/Blue head prints about 5 - 10 little lines. I checked the fuses again and they are both fine. I also changes the board that the printhead cable boards go to, nothing changed. So switched the heads to see if the few little lines that were printing would follow the head, no luck it still printed them on the black/blue head not on the red/yellow head. I also switched out the motherboard with my spare motherboard, but there is no difference. Is there anything else besides the motherboard, printhead cables that could cause this to happen. I would by another printhead to see if it was the printheads that just went bad, but do not want to spend the money if there is something else to check. Does anyone have any idea what might be going on? Thank you in advance!!
Kyle
Kyle
