sp540 cut/print waaay off
Stagecraft
Had a jam yesterday, Now when I do a print/cut, the cut is off alignment by almost two inches. Have tried the feed - scan adjustments, cleaned the encoder strip, resetting to default values, all to no avail. One other issue I'm finding is if I try to print a graphic and set it to center on the media, it too is substantially off...suggestions?
MichaelAlmand
I used to have a sp540, darn things are tough to print, lam and cut. Try turning off the heat setting. Now have a Re640 with a gx640 and I can cut up to 15' spot on. Knock on wood!
I never really had much luck with the sp540
Rafael_Tech
Question...
Does it happen on one side of the material and the it starts to close the gap between print and cut? Or the gap is even along the print?
CS-SignSupply
While the pinch rollers are down, manually try to lift each one at a time by hand... If you can lift them, the roller assembly may be cracked.
SublimeGraphics
Try running a environmental match, sounds weird i know but my dealer told me it re-aligns the head on the encoder strip when it does this.
Stagecraft
Thanks for the replies! We were in "blind panic" mode as we were stupidly busy and couldn't wait. Called in a tech from Proveer, he showed up thirty minutes after I phoned and had us back up and running in just over an hour.
Msrae
Rae
Were you able to tell what he did to fix it?
