Universal Industrial Sales
For some reason Graphtec was nice enough to not design a static output on there machines. It seems to me, and it just may be me, that as the vinyl comes out of the roll slides down the back basket, up across the cutting area, and down the front basket it builds up a lot of static. Yes i have said ouch a few times when touching the machine when receiving the static shock.
So i got some wire and stripped it completely, about 4 ft. taped it across the cutting area behind the rollers, got two more wires, stripped there ends about 1", used the bolt that holds the main bracket on the machine to mount the first wire (which i tied into the bare wire that goes into the cutting area), and i used another existing screw and tied the second wire into a screw below the cutting controls, then placed each wire into a seperate ground plug/hole in a power strip. Yes believe it or not my idea worked. A little red neck but hey i dont say ouch anymore. BUT!! i also stopped using the FABRIC catch on each side of the machine. But now my vinyl gets really dirty. ANYONE KNOW OF A SURE FIRE WAY TO GET RID OF STATIC WHILE USING THE CATCH'S????
