Stencil on painted concrete
d fleming
Aluminum composite material, or acrylic comp material, as well as about a hundred other names depending on who is selling it.
Billct2
Yes, for a graphic that size it may be simpilest to have it printed and router cut on a sheet of material that is thin enough to bend to the curve.
3Dsigns
The first problem with that, is my router only cuts about 50'' wide and this thing is to be over 60''. The next thing is, how would you gluie it to the concrete tower? Gorilla Glue? Liquid Nails?
Billct2
Like Gino showed, put a "balloon" shape around it, easily cut with a jigsaw. To attached use a combination of concrete fasteners and adhesive.
3Dsigns
Duh, I've been running that router so long, that I momentarily forgot what I cut my teeth on, I have used my Porter Cable oscillating sabre saw like forever. Yeah that would work.
But a sample just arrived, about an hour ago, of some new "U-blast" high tack sandblast stencil and It's very thin and conformable. I just tried it on a piece of bare concrete block and it sticks very well. Well enough to use as a mask. I think we will be going that route. Thanks!
