straighten lines
pablo11059
i am trying to figure out if there is a way to straighten a line. i see moving the nodes can do it but id just like to select the line then make it straight. i could move the nodes for weeks and still not get it, im sure there is a simple way im just new. thanks in advance
signage
By straighten line what do you mean? Is the line a curve and you want to make it straight or are you trying to make them parallel?
Mike Paul
Super Active Member
Select the points> use align horizontal, align vertical or align points on your path edit toolbar.
