then why not just use you printer profile as the source? It's no accident the RGB Yellow to SWOP Yellow had cyan in it. That's what you complained about originally.
do you know the difference between input and output profiles? RGB yellow to swop? what are you talking about? RGB yellow gets mapped if it is out of gamut of your printer and gets mapped according to what rendering intent you have chosen. we are talking about designing in RGB to maximize the color abilities of the printer ...or at least i am. i'm not going from RGB to swop...
Illustrator uses the same rendering intent for both vector and raster.They understand PostScript as they wrote it.
once again huh? i'm talking about the RIPs rendering intent not illustrator and if you make a file in illy with vectors and rasters or raster effects and have you rip set up with different rendering intents for vectors and rasters the colors will be different. so the RIPs rendering intent is what matters here
as I said I use RC always
there is nothing that should be used ALWAYS.. there are ALWAYS exceptions. why do you think a photolab uses perceptual? it looks better with photos. a sign is most of the time graphics so relative is better in our industry
Sorry it's common knowledge all inks have impurities in them
So?.... we are talking about the benefits of designing in RGB vs. your "CMYK printer profile".. not what inks have problems.
No what I am saying knowledge produces a better product
thats the exact same thing i said!!! if you have the color knowledge then by all means use adobeRGB or in your case this "printer profile" but if you don't and want the easiest way to get predictable RGB color use sRGB
We're printing to paper CMYK not to a monitor RGB
i know that ...but i am talking about maximizing the gamut of the CMYK or CMYKlclm or CMYKOG or what ever inkset... if you use RGB the RIP converts for the printers inkset... when i used a CMYKOG printer you can't get the orange or a lot of other color it was capable of if you didn't use RGB...
A profile doesn't alter the data it merely tells the application what colorspace it was created in. ie SWOP, or your printers. Simple
correct for input profiles...
SRGB was created for the WWW not for print.
sRGB was created for more than just the web
quoted from wikipedia
"sRGB is a standard
RGB color space created cooperatively by
HP and
Microsoft in
1996 for use on monitors, printers, and the
Internet."
