Stormyj
Just another guy
Anyone having problems with suction hoses clogging up? I bought some hose off ebay, says it was suppose to work, but ever since then, I have had multiple clogs. Causing problems with heads not getting cleaned properly. I am using after market inks, but never had that problem before. The tubes seem a bit softer then original tube, but i dont think they are collapsing with suction. Where do you get your tubing? The stuff is all over the place, but you never know how it is until you spend the money on a 25' roll. Also, I think it is supposed to be 3mmod 1.8mm id solvent resistant nylon? Is that right?
