Summa F Series
HaroldDesign
Anyone running the Summa F series (flatbed)? I didn't find much info in searching. Are they any good for cutting 3mm+ pvc, foamcore, etc...?
:thankyou:
Dice
I'm scratching my head why anyone would buy one of these. It's so small. 63" x 47"? I talked to the techs and looked at one when it was in development and even the techs didn't understand the small size.
Can't cut a 4 x 8 sheet, and want 80k for the thing?
Jim Doggett
It's made in Belgium, where 1.6 x 1.2 meters is a round number. But I think standard sheet material size in Europe is 1.2 x 2.4 meters. So it's a bit small on two continents, I'd think.
Zünd G3 is amazing if you have deep pockets; otherwise MultiCAM is, I beleive, the most feature-rich for the price. Gerber, too, has nice routers.
My $0.02,
HaroldDesign
Currently the routing work is done on the outside. 99% of them would fit on the bed. I would simply gang things up on the 4' x 8' in a manner that I can first give the sheet rough trimming to fit clusters of parts on the cutter. I agree a larger cutter would be nice, but there is quite a jump in price.
nucleus
Hey Dice this this is actually on a conveyor type setup so because it can hold up to 67" and cuts up 63" wide it can do a 5' x 10' no problem and in fact it can go up to 150'
here is what there website says.
Cut Area
63 IN. (160 CM) WIDE x 47.2 IN. (120 CM) LONG
UP TO 164 FT. (50 M)
bigben
I'm also checking this cutter. I love my summa d160, but why would I take a summa F with odd size before a multicam digital express as an example.
rshacklett
Wholesale Sign Specialist
We have one...
Its actually great machine. If you're doing a boatload of 4x8 work all day long, then yes one with a bigger bed is going to be more efficient. However, if you're doing roll work, its great, and it even does a great job on 4x8 sheets.
We do a real mixtures of sizes and materials, and for $80k vs $150 for Esko or Zund with same function, its a real deal.
Its ability to move the materials and continue cutting (segmenting) works perfect, and rarely gets out of register. We run ours really hard, and its working great!
