We got the Summa from Northlight Color. they sent the guide but honestly its a little confusing. As with anything you can spend a lot of money on the ancillary products so I'm wondering if anyone has any good suggestions. We do not have a pneumatic tools ordered. we do have the 1.4 router though.Good afternoon,
The air compressor that you select will vary depending on whether you are getting any of the pneumatic tools like the POT or high frequency router, but if you aren't getting any of the pneumatic tools a "pancake" compressor will be sufficient for the media advance clamps. If you are getting some of the pneumatic tools, a lot of the companies that we work with like to use the California Air Tools compressors and the reviews have been solid on those. Not sure who you purchased the 1612 from, but we usually send out a full site preparation guide ahead of time that lists out all the specs for the compressor, electrical, etc. so you might check with your dealer to see if they have anything like that.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext. 112
philj@airmark.com
It doesn't take much. My building has a big compressor setup as it was an old forklift service building. But when that went out for a while, I just used a small pancake compressor for a few weeks and it worked just fine. I would get a decent sized tank and a super quiet one if it's gonna be in the same area.We got the Summa from Northlight Color. they sent the guide but honestly its a little confusing. As with anything you can spend a lot of money on the ancillary products so I'm wondering if anyone has any good suggestions. We do not have a pneumatic tools ordered. we do have the 1.4 router though.
Phil, from what I read in the Summa F Series User Manual Rev15 (page 1-19, section 1.5.6), the HF router appears to still be an electric motor (like the standard router) with a pneumatic "clamp" for the collet for the bit. I imagine since it is just the collet using the air pressure, that a large capacity compressor is not needed for the HF router. We are going to get our F1612 up and running hopefully in the next two weeks and we shall find out!! We purchased this compressor to use and we have the EOT, not the POT. FORTRESS 2 Gallon, 135 PSI Ultra Quiet Oil-Free Hand-Carry Jobsite Air CompressorGood afternoon,
Best regards,
Phil Johnson
Airmark Corporation
philj@airmark.com
You need dry air (air dryer) for the POT and HF router. That's why you need to go up with the compressor.Phil, from what I read in the Summa F Series User Manual Rev15 (page 1-19, section 1.5.6), the HF router appears to still be an electric motor with a pneumatic "clamp" for the collet for the bit. I imagine since it is just the collet using the air pressure, that a large capacity compressor is not needed for the HF router. We are going to get our F1612 up and running hopefully in the next two weeks and we shall find out!! We purchased this compressor to use and we have the EOT, not the POT. FORTRESS 2 Gallon, 135 PSI Ultra Quiet Oil-Free Hand-Carry Jobsite Air Compressor
