We have been using goproduce (Roll Cutter edition) for a few months... basically the beta to this. It's a great change and we look forward to unlocking the Pro features once allowed.Looks pretty much the same as goproduce for their flatbed cutters, should be a nice add on for a roll cutter.
Hopefully, this is also the precursor to ethernet only for the cam versions of the S2. It will be nice to not be tethered to a computer for cutter placement.
Is this with the camera? We tried a conversion extender, and it caused issues with the camera.Side note about the cable. We have the cutter around 100’ away from the computer. Physical distance is only 20 feet but all our data drops come from the warehouse roof. We are running a simple usb to cat 5e converter. It allows us to run a virtually 300’ cat5e cable from machine to computer.
at the current 100’ cable we do NOT notice any data lag and very data heavy flex cut files don’t have an impact on time cutting or lag. Certainly something to explore if you need some extra distance.
Great news about the update - something I will have to look into. Thanks for the notice!
Being a software limitation is something that has been mentioned previously to us by Summa.Don't hold your breath, our F1612 is only USB, and the cable can't exceed 9 feet...
Nice find, I will be checking it out tomorrow. There are updated versions of Summa Cutter Controls and S Class 2 firmware as well.
Yes, like I said we were told previously that it was a software limitation. Hopefully, with this new release, that limitation will eventually go away.The drivers to manage the camera installed on the TC and F series are available only for Windows and only through USB. This is the reason they need a dedicated PC with Windows and an USB connection to comunicate with the camera.
Ok dude, clearly you are not reading what I wrote or you have inside knowledge that contradicts Summa techs.TC plotters, as F series with GoProduce, will continue to need a windows PC and an USB connection. With GoSign you can avoid to run Summa Cutter Control program in background to manage the camera because GoSign communicates directly with the camera, but the plotter always must be connected through USB.
Summa Cutter Control program will continue to have to be used with RIPs and others software.
Is this only available for the S2 or can it be used on the older models as well?
