Summa S2 T160 - Can't lower OPOS
lillhannus
Hi all,
My Summa can't lower it´s OPOS-cam and says it is due to the encoder not working properly.
Is there any software solution to this or do I need a new encoder?
Apparently I can't buy just the encoder card. My supplier says I need to buy a new head which I think is bs.
Regards,
Jonas
FrankW
If you really have OPOS-CAM, then the camera will regularly not lowered. If you have regular OPOS X, this sensor will be lowered.
But, could it be that your cutter reports a problem with lowering the tool?
I agree that you need to buy a new head.
lillhannus
Sorry, OPOS X it is.
The tool doesn't lower either.
"Up-down encoder not working" it says
lillhannus
Thought I´d share with you since I fixed the machine last week.
I got tired of it and put it to rest for a while. The service guy wanted to exchange the head and that should have cost me about 2000 USD.
Anyways. I found the monitor in the maintenance menu and from there I could see that there was nothing wrong with the encoder at all.
After some fiddling and sniffing i checked the coil and found that one of the wires was loose. I soldered it back together and now everything works just fine.
jimmmi
Whats the difference between the OPOS-CAM and OPOS-X?
PrintItBig
When we first got our s2 t class we were getting loads of “can’t lower OPOS” messages. The supplier changed the whole head under warranty.
iPrintStuff
Prints stuff
Yeah as far as I’m aware there’s not much to these machines. There’s the head, main board and forward and back motors with built in encoders as far as I’m aware.
just a good chance if anything goes wrong it’ll be an expensive part lol
