Need Help SUMMACUTD60/WINDOWS10 COMMUNICATION
Discussion in 'Installation Equipment & Techniques' started by selina09, Jan 26, 2020.
  1. selina09
    selina09 New Member
    1
    Jul 26, 2014
    ky
    HELP NEEDED SUMMACUTD60/WINDOWS10 COMMUNICATION
    I PURCHASED A NEW COMPUTER DUE TO MICROSOFT 7 NO LONGER BEING SUPPORTED. NOW WITH THE NEW COMPUTER WINDOWS 10 IT DOES NOT COMMUNICATE WITH MY SUMMACUT D60 CUTTER. IT WAS "FAILED TO OPEN THE COMMUNICATION PORT" AND "COULD NOT OPEN SUMMA SOCKET CUTTER".. I HAVE MULTIPLE TIMES DOWNLOADED THE NEW DRIVER AND UNINSTALLED IT. NOTHING CHANGES. IT CONTINUES TO WORK ON MY OLD COMPUTER WITH THE USD BUT NOT NEW ONE. THE LIGHT ON THE BACK STAYS LIT ON OLD COMPUTER BUT ON NEW ONE, IT FLASHES AND THEN GOES OFF. ANY HELP WITH GETTING THESE GUYS TO COMMUNICATE WOULD BE GREATLY APPRECIATED.
  2. jimdtg
    jimdtg Member
    305
    23
    18
    Jun 18, 2017
    Some places in earth
    Windows 7 is no longer supported for updates, bugs fixing, but it is still stable OS and you can use it without problem.
  3. wes70
    wes70 Very Active Member
    1,667
    10
    38
    Oct 31, 2005
    Canada
    I have an old d60 and run it with win10. I just downloaded the new summa drivers and use FlexiStarter 10 as a bridge program with Coreldraw.
  4. Joe House
    Joe House Active Member
    993
    222
    43
    Feb 5, 2004
    WA
    Check your firewall and antivirus settings. They often get in the way of sign software and communications with external devices. Usually you can turn them off for a short time for diagnostic purposes, but for long term, you'll want to add an exception to the security software for you sign software.
    Good Luck,
    • Like Like x 2
  5. decalman
    decalman Active Member
    773
    62
    28
    Sep 2, 2012
    phoenix
    This reminds me of around ,2004, I had a new Roland 24.... and they discontinued XP. I had to find old XPs for years, because Roland didn't make drivers for Windows 7.
    The machine would work with Vista but it was unstable. I had to suffer trying to find XP used laptops . Total drag. I still kind of upset with Roland over this. My new plotter was a Summa d-75. Fills my needs perfectly.
    • Like Like x 1
  6. Cordell-Designs
    Cordell-Designs New Member
    15
    Jan 7, 2016
    IL
    How are you connecting to your cutter? I connect via network cable (there is a small 5 port gigabit switch between my pc and the cutter). Sometimes I get that message and rebooting the cutter fixes it.
    All I've ever done is install the Summa software and drivers and everything works fine. I'm on Windows 10 build version 1903 and just cut some decals tonight.
  7. PHILJOHNSON
    PHILJOHNSON Sales Manager
    1,070
    69
    48
    Jul 23, 2010
    Seattle, WA
    Hello Selina09,
    This is an easy fix and I can walk you through it if you are still having difficulties. Shoot me an email to philj@airmark.com or you can send me a PM through this site and I will reach out to walk you through it.
    Best regards,
    Phil Johnson
    Airmark Corporation
    (800)527-7778, ext 112
    philj@airmark.com
  8. kp77
    kp77 New Member
    1
    Feb 28, 2020
    United States
    I am having the exact same issues as Selina09 . Any help would be GREATLY appreciated!
  9. PHILJOHNSON
    1,070
    69
    48
    Jul 23, 2010
    Seattle, WA
    I received your email and sent a reply. Did you see my email and do you have time to get this resolved today?
    Best regards,
    Phil Johnson
    Airmark Corporation
    philj@airmark.com
  10. jessign78
    jessign78 New Member
    6
    Jul 14, 2014
    Hi,
    I am having this issue with an old xp. Just all of a sudden won’t recognize the Summa D60/u. Would you be so kind as to help me out too?
    Thanks.
