Switching from Sam to OEM on a 9000s
Scott Reynolds
The Sam ink is suppose to be "plug & play", but what about going back the OEM? Can I just put the OEM cart and the charge the ink? The sub tanks are big, I would hate to have to pump out that much ink.
Thanks, Scott
CS-SignSupply-TT
Once you reverse pump the inks back into the SAM carts, what are you going to do with the inks? What has happened to cause you to consider this option?
