Is your directory made of a single panel, or are there individual "slats" for each tenant? Individual slats make much more sense since they can be updated easily when people move, and you can add braille much easier on a 36" x 4" piece than a 36"x60"In my current example, I have to make a directory with braille. The board is 36in wide X 60in high. How would I add the braille on this?
You're that guy hand placing applique! Have you tried it with the rotary engraver after the material is already stuck? I'm so curious how this works out. Got a shot of a finished product?
Speed mostly, the laser cuts the applique much faster then the rotary, the laundry room sign is about 8"x8" and the laser would take about 20 seconds to cut the applique on that sign, plus there are no little chips to clean up.Oh I see. Yeah, every time I've thought "I'll make a really cool sign with raised copy on a glossy material!" Then after 15 minutes of picking at adhesive, I give up. It shouldn't matter much, ADA requires a matte or at least non-glossy finish. Any reason you don't use the rotary for this? These do look nice and crisp.
Try Cadlink.comI would like to know what kind of equipment it take to make tactile and braille signs? I'm very intrigued in this market and would like to learn more about it. I've googled the topic but did not get a clear answers.
Thanks.
cadlink.comI would like to know what kind of equipment it take to make tactile and braille signs? I'm very intrigued in this market and would like to learn more about it. I've googled the topic but did not get a clear answers.
Thanks.
Just a word regarding UV flatbed printing tactile ADA signs, I have done some experiments on our Fluidcolor R84F, and managed to print tactile text a little over 1/32" in height in a single pass using white ink to build up the height quickly and an overcoat of whatever color is needed. (I say one pass, the machine is really doing multiple passes, but it's all done in one print run.) I realize this is not the answer for mass production because it is a little slow, but for small jobs its great and very versatile.We make a ton of tactile & braille signs, we use a laser engraver for cutting the rowmark applique, and a rotary engraver for the raster braille.
There is also the photopolymer process, which is great for large runs, but the inevitable 3 signs at the end of the job that got missed add up very quickly, it's a very setup heavy process similar to screenprinting, we have made quite a few one-off signs for companies that used photopolymer originally in their building, but now don't want to spend $500 on a single sign.
You can also flatbed print them on certain flatbed machines, however my understanding of this process is that it's EXTREMLY slow as the printer has to print quite few layers of in to build up the height needed to be ADA compliant, it seems cool for small order, but if you get an order for 500 signs your labour is going to kill your profit.
I take it you recommend this one? I got a quote back from them and it seems pretty high, like my cost being the same as what I'm seeing on a retail office sign site for a similar sign. Graphic Components responded saying they're at capacity and not taking new customers, but gave me a few other shops to try:Vista Systems
Canon claims to be able to print braille with the Colorado as the gel ink allows a precise and fast build. I haven't seen it done yet though.
