Click to Support Signs101 ...
Sort of. You deform the part of the grommet that is peened over the washer with long nose pliers. Done properly the grommet and washer simply fall off..
Use a set of needle nose pliers and bend up half of the backside on the grommet. Once you can get the needle nose to have a good grip on the grommet backing clamp down tight and twist the pliers so the grommet wraps off onto the plier nose. Easiest way I have found so far.
