I have a document with a lot of small text that I need to edit. The text is still editable - but the lines are broken into small sections of text - instead of one connected text block. Is there anyway to join all the little sections of text back together? Thanks!
One way that happens is saving down from a newer version of Illustrator. If that is the case, you should re-open it in the newer version. If you must do your editing in an older version, maybe the text could be copied & pasted, saved in a word processing format, or emailed to yourself...
...if it never was in a newer version, than I'm not sure what other options exist... but I'd guess it was brought in from some other program, so I'd try to go back to wherever the typesetting was originally done.
