Question thinking of bying a cjv30-1000...................
Discussion in 'Mimaki' started by thesignworks, Feb 2, 2019.
  1. thesignworks
    thesignworks Member
    92
    Aug 10, 2009
    london
    comes with rasterlink 5 pro sg - does this run windows 10
    IF the version comes with the printer, is the license mine -
    do I go online and update it - will I have the license - I cannot remove it from the old computer it was originally installed on.
    the printer is a 2010 model.
    the head has been trashed - it hit the paper clamp and has a gouge in it
    IT flashes no errors.
    It goes through the motions.
    -I have a r2880 for the head, I think the firmware was at 2.80
    -should I go for a head from a wider 7880/7800
    its been sat a while,
    do I fit a new ink pump and lines
    capping station
    flush out the old solvent manifold
    do I need 8 carts with 8 arc chips
    I plan on refilling stock carts fitting arc chips
    what am I missing?
  2. thesignworks
    thesignworks Member
    92
    Aug 10, 2009
    london
    what version of firmware lets me use a r2880 head
    I would prefer a Teflon/gold dx5
    IF I use the 'latest' firmware for a cjv
    WILL a decoder card work?
  3. Neil
    Neil Member
    337
    11
    18
    Aug 25, 2005
    Adelaide, South Australia
    I think the main thing you are m issing here is that it's only 1000mm wide.
    So, you'll have to have all your 1370 rolls ordered cut down to fit.
    And you won't be able to print an 8x4 sign.
    Give it a miss and get a CJV30-130 instead.
