Red loctite needs to be heated to be removed.I heard you can get a cheap, disposable screwdriver and dip the tip in epoxy. Hold the screwdriver in place (or figure out a way to keep it in place while the epoxy sets). That should work, right?
Or, you could do the baking soda and superglue trick, fill up the cavity completely, let it all dry and then use a Dremmel or something to carve out a notch for a flat head screwdriver? Although, that's probably overthinking it.
...also, I remember someone telling me that heat helps with screws installed with Loctite. To be honest, I don't know how much heat you'd need and looking at where you're working, I think a heat gun might create more problems than solve, but for what it's worth...
Only a fool would use red loctite in a printhead
This actually seems pretty likely, quote from a blog post about them moving production from Japan recently: "As part of efforts to improve production efficiency and enhance price competitiveness, mass production was transferred from Japan in 2021." https://www.rolanddg.com/en/news/2023/230523-thailand-factory-new-buildingIt may actually be a JIS screw, but still leaning towards pozidriv.
And the more we farm out everything to the rest of the world to build for us, the more tools we'll need to fix em'. Now you gotta figure out if something is SAE, metric, imperial, if it's phillips or pozidrive.... Not to mention all the different security fasteners so you can't open what you own.This actually seems pretty likely, quote from a blog post about them moving production from Japan recently: "As part of efforts to improve production efficiency and enhance price competitiveness, mass production was transferred from Japan in 2021." https://www.rolanddg.com/en/news/2023/230523-thailand-factory-new-building
It's really an awesome screw, but a curse to introduce into a world full of phillips. They cannot be used with a phillips driver, as they have a very high chance of camming out because the driver doesn't fully seat in the head.
I'm embarrassed to say I'm a big fan of robertson heads...
Heat might be worth a try. Use a soldering iron with a sharp tip. The irons are not much bigger than a paint marker and the heat would only be on the screw. A little heat and a good tip on the screwdriver should do it....also, I remember someone telling me that heat helps with screws installed with Loctite. To be honest, I don't know how much heat you'd need and looking at where you're working, I think a heat gun might create more problems than solve, but for what it's worth...
Soldering iron, that is brilliant! They make induction bolt heaters but never wanted to spend the money on one. This trick here should be close enough.Heat might be worth a try. Use a soldering iron with a sharp tip. The irons are not much bigger than a paint marker and the heat would only be on the screw. A little heat and a good tip on the screwdriver should do it.
I am a fan of thermal stress after changing out two O2 sensors on my F150 just this week. MAPP torch made them give up and spin right out. I did pre-heat them with about 30 minutes of cursing at the Ford engineers for not rotating the sensor position about 5 degrees down on the exhaust pipe so a removal tool could be put on it.
That or heating the driver and resting it on the bolt head. This thing came to mind. My mechanic buddy has one of these snapon butane soldering irons with a hot air tip. It's like a ~3/16" diameter tip that puts out enough heat for heat shrink/solder combo connectors, I really need to borrow it and try it out for spot fixes on wraps.Soldering iron, that is brilliant!
Jewellers extractors will be way too small, they are designed for removing tiny screws in watches and that sort of thing. To be honest, and having had experience with having to remove head screws that have been stripped in the past, your easiest option is just to drill the head off. It will only take a few seconds with a decent drill bit.I"m having trouble finding jeweler's screw extractors but did find these:
Amazon has them, the reviews seem good, but still investigating.
