trimmer cutter
cardfan4342
Anyone using a rail type trimmer to cut coro, pvc, prints etc. maybe a little feedback on brands, types, pros and cons. Thanks in advance
Fred Weiss
I use a 100" Keen Cutter Javelin with the Big Bench table they sell separately. We cut anything with it that one might cut with a utility knife including weeded and masked vinyl, prints, coroplast, PVC foam up to 6 mm, etc. We sometimes also use it for magnetic sheet but it will dull the blade very quickly.
Techman
i used a matt cutter.. professional quality. Seal procut F48. Heavy duty cuts 52" wide.
Cuts coro anything that a box cutter carpet knife will cut. Even score aluminum sheets for cutting.
One tool i couldnt do with out.
