T
Tropics09
Guest
now let the search for someone who can profile my printer begin. Thanks for the help guys!
Are you guys profiling your own media? If not and you cant find a premade profile that works then you might consider buying an i1 and do it yourself.
I had a hell of a time getting good reds out of my Mutoh printer. I ended up printing the CYMK chart built into Flexi then I use the color squares to determine the values to use in my work. It matters not how it looks on the screen because I know the values I specify will produce the output I want.
The other thing I learned is that your CYMK printers have a very limited gamut of colors. If I had to do it all over again I would buy a printer that uses 6 inks that are needed for a wide gamut of brilliant colors.
Judging from your previous posts I don't think it is a good idea for you to buy an Eye1 now. Eye1 is just a tool to build profile but you need deep knowledge on Color ICC to do it properly. Your best bet is having an expert come over and set it up for you. If you want to test the ink for red color you can rip/print your test file with NO ICC attached (iprovided you know how to turn it off in the Rip). Overall color may not look great but the printer will do exactly what you asked.
Hope this would help
there is a rendering intend option, within it you have an option for pure hue. Check the red and retry..I had the same problem while using flexi with our xr.. works like a champ.
Scott
