blacknbart
Producing art work in Illustrator CS4 and or 5
Producing Reg Marks with the plug in Cutting Master 2 (Graphtec)
Artwork sent to Onyx Rip
Then to HP L25500
Trying to cut with my FC8000 Graphtec.
It seems as though a lot of Graphtec users have this initial problem of the sensor not reading the reg marks correctly. Reads one, two, three or four marks before failing. ( Mark Scan Error!! ) I've even had mine read two reg mark successfully then go on to the third mark only to fall short about an inch or so. It would read the white space then beep with an error. I have had some success with designs printed on matte vinyl with no lam, but the real problem in the glossy vinyl with gloss lam. Hell I need this to run every possible solution possible. Glossy in a staple!! I need some hints, fixes, and or guidance to get me past the hurdle. Here are some questions:
What color black should the reg marks be after I produce them in Cutting Master 2? I see #000000
Can the Onxy rip screw with the color of the regs marks when it passes on to the HP Printer?
Do I need the Onxy new Graphtec FC8000 Cutter Driver for Version 7.3
Then to HP L25500
