oozawekwun
Mutoh Rockhopper II 64 running current firmware with wave.
Onyx PosterShop 7.3.2.16
Ultra Eco Mutoh Ink
Media - banding happens in all media, more visible in gloss media
Problem. Images that contain dark areas will show what looks like white bands. Lighter shaded areas will not show this banding. See the two images. Notice the white bands in the dark areas?
I've adjusted the feed adjust and can't get rid of this white band. I'm assuming that by using wave the banding would be a sine wave type of band not a straight line band. I can use the rip to print unidirectional at the finest setting and the bands will still show up however the space between then is smaller.
Nozzle check is fine. I booted the printer into maintenance mode and ran some tests. The third image is from the Front and back test. Again I'm assuming that the blocks are supposed to be solid colors. If this is the case does anyone have any suggestions?
TJ
Ultra Eco Mutoh Ink
TJ
