I've got a large problem after an ultrasonic cleaning and am hoping someone can help. I've got a Roland SC545EX and I had a head that was a bit clogged up like only firing half the test print. I eventually had had enough and researched ultrasonic cleaning, and from what I could read it sounded like I couldn't hurt it any worse than it was... I pull the head out, ultrasonic clean it in Roland Cleaning Solution for 480 seconds at which point I attached a syringe to the adapter plate and force cleaning solution through the head. With a little pressure it ended up coming out in what looked to be a GREAT pattern. I hook everything back up and now the head doesn't fire at all. I tried pulling ink through the capping station with a syringe (then a shop-vac) and am getting NOTHING AT ALL where before I could always get at least something through the syringe/vac method. Does anyone have any clue as to what could be wrong? Have I damaged that head beyond repair? I've hooked my syringe up to the ink supply line before the damper and got ink. I've done the same thing after the damper and before the head and got ink, I just cant seem to get ANYTHING from the head. Any advice here would be monumental!
Thanks in advance,
Andrew
Thanks in advance,
Andrew
