ups
Discussion in 'Roland' started by graphix, Mar 31, 2010.
  1. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    uninterupted power supply..as you know in earlier post i had to have a power supply rebuilt for a sp540 before i powered it back up i bought a ups...printer been doing fine came out today in shop and the ups was on battery backup and printer was off...most of had another surge..over the years i have lost probabally 3 pc's which showed bulged resistors.now learning about the surges i am wandering if i am getting surges from the power lines. i live in old town with a grocery store across street with lots of coolers just wondering if they may be the culprits....anyway i have a tripp-lite 350 va ups is this big enough on the battery side for my printer or should i use this on the side that is just surge protector..
    can someone please explain i know if i didnt have this hooked up it may have popped another power supply..thanks
  2. signage
    signage Major Contributor
    9,517
    75
    48
    Oct 5, 2005
    Penn
    read here I explained about it in this thread.
  3. Dice
    Dice Active Member
    647
    Ya your not anywhere near what you need on a printer. Look at getting a 1500VA or bigger.
    Also the surge protectors work by monitoring the line and outputting any extra voltage or amperage though the neutral (ground). If your in an old building it's possible that you aren't grounded well. You might want to have an electrician come out and check it out. They should give you an estimate for free.
  4. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    ok thanks ...well those devices are expensive...what alternatives do i have.,...i built a add on 200 amp box..all outlets grounded...but i am hooked up in front part of building that is 100 amp jumpered from 200 amp box...should i run a single line to printer with 30 amp breaker....i really not concerned about getting through a print job (don't print anything major) i am just worried about the surges...,.if this makes since...
    really didnt know about the ups to so to get by what do i need to do...the lesser expensive way..thanks
  5. signage
    9,517
    75
    48
    Oct 5, 2005
    Penn
    If I was you I would contact a local electrician and talk to them about your concerns and possibly a whole panel surge suppressor!
  6. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    The caps very likely were not damaged by a power surge.
    There was a rash of bad capacitors in plenty of PC's previous years.
    The cause was some technician stole a japanese design. Sold it to a chinese company but with one little surprise. The design company used the oldest of security methods in the books. That is they left out a very important detail on how to preserve the oil that acts as a insulator.
    The oil that lines those capacitors was not treated with the correct preservative. Thus the caps went bad and bulged out tops.
    It ruined the chinese company and the original designer company is making out like bandits replacing those bad caps. Plus they knocked out the theef company in one swoop.
    Industrial espionage at its best.
  7. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    thanks
  8. graphix
    graphix Member
    404
    Dec 15, 2005
    Ohio
    what shpuld i do mean time...thanks
