van wrap window question
petepaz
doing a partial wrap on a van to cover the windows. normally after i go over the windows i cut around the edges and squeegee all around so everything is tucked in. question is what if i don't make those cuts and just leave full vinyl over the window and van sides. will i be asking for failure suck as the vinyl ripping and curling up? doesn't matter either way just thinking cosmetically it looks better in one solid piece with out the cuts around the window edges.
Baz
Seperate parts move independantly. If you don't cut it, it will stretch where the gap is, it will ripple and eventually crack.
