vehicle outline debate
Discussion in 'Clipart, Vehicle Templates and Digital Files' started by flat rock stan, Apr 10, 2007.
  1. flat rock stan
    flat rock stan Member
    127
    After searching this site for info on vehicle outline programs it seems most members here are divided on the worth of just a picture of the car and the different programs. While searching the net I came up with 2 – 3 company’s that sell software for around 500 to 600 bucks. Being a newbie and a slow learning one at that I thought I would ask for feedback or suggestions.
    thanks
    Stan
  2. gvgraphics
    gvgraphics Very Active Member
    2,182
    2
    It all depends on you preference. Some like the templates and some use a magnetic circle or square stuck to the vehicle set to a specific size. Then enlarge there picture till the shape is the size it is suppose to be. Personally I do it both ways. It depends on if I can get to see the vehicle or not. I have allot of clients that are a hour or more away. The templates work good in this case. I only have to go and install, instead of a trip to measure and a trip to install. It all boils down to your budget and preference.
  3. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    the problem with the cd's is they do not have all the vehicles on them.
    You spend a couple hundred on them but soon find that some vehicles are not there.
  4. gvgraphics
    2,182
    2
    I agree with techman. But I have found that most of the common ones are on them. Then again they have makes and models that are over seas only as well. They come in handy but I wouldn't depend on them for every job.
  5. flat rock stan
    127
    If I get one to have around which company in your opinion gives the most bang for the buck!
  6. cinemasign.grafix
    cinemasign.grafix Member
    469
    Aug 14, 2005
    Pro vehicle outlines & camera should cover most of what you will need. If you have the time , shop around for a while & try to pick up one that is a couple years old. All the newer models can be easily found at the local dealership lot or in their service area.
  7. jeroen
    jeroen Member
    258
    check www.mr-clipart.com
    for about $150 you get their collection on dvd and you get access to their online database for one year
  8. Poconopete
    Poconopete Very Active Member
    1,299
    1
    I recently got the 06 version of mr-clipart from summa for $99. summastore.com/clipart.php?
  9. SirSlarty
    SirSlarty Member
    460
    Jan 23, 2006
    Mr Clipart had helped our shop numerous times and not just for the vehicle templates.
  10. Checkers
    Checkers Very Active Member
    2,698
    3
    I found Pro Vehicle Outlines to be the most accurate and it contains the largest collection of commercial vehicles sold in North America.
    It's been several years since I've tried the other programs, so they may have improved in quality and quantity since then.
    Checkers
