Versacamm pump upgrade help please.sp300
Discussion in 'Roland' started by Ken, May 13, 2007.
  1. Ken
    Ken Major Contributor
    5,484
    2
    38
    Feb 7, 2005
    BC
    SP300
    I've installed the new pump and that went well. The new pump makes that clicking noise but I understand that is normal.
    I currently have firmware v1.4 but I'm trying to update to v6.2
    When I try to update the firmware the sp300 does not appear on the list of printers available. Just my desktop printer shows on the list. I rebooted but that didn't help.
    In control panel it shows the Roland as offline. When I check the properties it shows as connected to my USB port.
    How do I get the sp300 into the list in the updater?
    Also after replacing the pump, when I start the sp300 I get sheet set error that I cant seem to get rid of.
    I also replaced the flex cable that goes to the cutting head at the same time.
    Are these problems connected?
    Thanks.
    Ken
  2. BobbyFosson
    BobbyFosson Member
    401
    unplug the desktop printer and reboot... then try again.
    Thinking about the sheet set error
  3. Ken
    5,484
    2
    38
    Feb 7, 2005
    BC
    Ok, I unplugged the desktop but now nothing shows in the list in the updater
    list.
    Thanks anyhow. I'm hoping my tech guy will reply to my e-mail today.
    Would you phone him on Mothers day?
    Ken
  4. Ken
    5,484
    2
    38
    Feb 7, 2005
    BC
    Made some progress...but..
    Un-installed versacamm driver and re-installed and that allowed me to continue the firmware update. Also did the Max ink switch.
    But..now I get an invalid right pinch roller position message and can't seem to get that to go away.
    The sensor check function doesn't seem to check anything.
    Help..anyone?
    TIA.
    Ken
