Versacamm trouble finding registration dot!
Tony Rome
I have been dealing with this for too long.
When I go to cut after print it takes like 4 times of not finding the registration dot to finally get it to find it.
I have tried base point on/off
Shining a light (works a decent amount of times but not enough).
Has anyone had this problem, it is so frustrating because I have toi wait for it to cancel and start all over every time it fails.
Versacamm SP540V
Tony Rome
yes everything I print, what is weird is it seems it gets closer to finding it every time. Almost like it needs a few runs to get it.
Malkin
I set the knife directly over the spot I have marked here with the pink X, and hit basepoint. Always work a treat.
Things that you should also do:
-When doing the print run, set the basepoint inboard a little. I like to use a minimum of .5" or 1" if possible.
-Don't use the "center on media"
-Load your media straight, for both the printing and the cutting.
-Make sure the marks are clear with no imperfections (like a bubble or dirt in the lam)
Cyw
For fear of jinxing myself, I can't remember the last time I've ever had my VC not read the marks.
I set them up, like shown above in Malkin's picture but just a little farther over. We leave a slight more wiggle room (white space).
Two things that are very important, (1) DON'T center media when setting up your file and (2) don't bother getting media size again when sending the job through to be cut.
You can even move the pinch rollers, it won't matter........as long as you don't muck around with those 2 settings.
VTG
Tony, I had a similar problem with the Roland sensor not finding the registration dot. I tried a handful of different things but to no avail. I finally arrived at a solution that works every time now. However, make sure you've checked everything else first (i.e. clean sensor, no "silvering", straight media, and do not select "center on media" ... as Malkin already pointed out).
1) After you finish your print & lam process, load the media back into the machine as straight as you can.
2) Don't worry about lining up the registration marks with the cutting strip at this point.
3) Lock down the rollers, and let the print head go back and forth to measure the media width.
4) Now press and hold the ^ arrow to "rewind" the media until the leading edge is just past the last set of vacuum holes (as far back as it goes).
5) Now lift up the rollers (lift up the lever, but make sure you hold the media in position so it doesn't slide out of the back of the machine).
6) Then lock the rollers back down (the media should NOT have moved, the leading edge should still be just past the last set of vacuum holes).
7) The printhead will go back and forth again (measuring the media width) and then your media will advance out an inch or two like normal.
8) If you look at your registration marks now, they should be almost directly on top (or maybe 1/16 inch behind) the cutting strip.
9) RIP and Print (or in this case, Cut)
Sounds crazy, but this process works for me every time.
Let us know.
Tony Rome
OK well two things, I always put the knife over the exact middle of the dot not on the edge, I had no idea it went on the edge so I will try that.
Does anyone else put it in the middle of the dot?
Also, I center the media...a lot, so I will stop that as well.
Will let you know.
THANKS!
Cyw
Between those 2 things, I'm betting that's where you've been messing up.
Dont ever use that center on media option if you're planning to do a print/lam/cut
Not sure about everyone else but we set the circle about a quarter inch to the left of and centered to, the media clamp
I really don't have any trouble at all
We leave probably about a quarter inch of space between the circle and the clamp.
You don't have to move or mess with the knife position at all
The printer reads the marks immediately, first time, every time.
I'll take a picture in the morning if you think it will help
Sign Works
Folks ... Stop saying "Do Not Use Center On Media Option". It does not effect the print/lam/cut operation, I use it most always and in over 6 years have never had any error in reading registration marks.
Tony Rome
Very interesting, looking forward to pic.
Are you saying you don't even bother positioning the knife over the dot?
I want to run a test but too busy today, hopefully tomorrow.
Thanks to ALL!
Wheeler
If all the others fail you can set it up manually, Its on page 83 in my manual. Set your B123 points and send to printer, when it starts searching for cropmarks just hit cancel and enter. Starts cutting.
Sometimes I think it is more dead on than using the auto search, I wouldn't want to do anything very long though...
DizzyMarkus
Same here, if its not full I "center on media" -- lam it and reinsert with the reggie marks aligned with the cutting strip ---I dont put the blade in the middle of the dot, edge of the dot nothing, line em up witht he cutting strip andit finds it everytime ;0)
Markus
Tony Rome
Wow, well first time I tried this it worked, I will let you know if it was just luck but don't think so.
Thanks, and especially thanks for posting the pic.
Thanks EVERYONE who answered!
Cyw
Waiting to see photo????????????
:thankyou:
My son got hit by a car Tuesday evening........getting a photo posted isn't on the top of my priority list.
Following a medevac helicopter up the Parkway took precedence.
......just got back from the trauma center and thought I'd relax for a minute.....read my email and a few posts on a few forums.
Lovely message.
Are you some kind of jerk???????????????????????????????????????
oh look, I know how to use the question mark keystroke too! Cool Beans.
Thanks for the visual
MichaelAlmand
Lovely message.
My thoughts are with you... Hope everything will be okay...
