VersaWorks Problem
Discussion in 'Roland' started by inthesignbiz, Jun 27, 2012.
  1. After setting up a file in Job Settings -> Click OK.
    Program freezes.
    I have un installed and re-installed 3 or 4 times.
    Works OK for a little while then starts acting up again.
    All updates have been downloaded and installed.
    Any ideas?
  2. Rob_maxgrafix
    Rob_maxgrafix Member
    51
    Dec 24, 2011
    what else is running on your pc while versaworks is running?
  3. Mike Paul
    Mike Paul Major Contributor
    5,437
    8
    38
    Dec 30, 2003
    NJ
  4. rjssigns
    rjssigns Major Contributor
    4,468
    282
    83
    Jun 4, 2007
    Home Office
    Depending on the vintage of your Roland you should shut off the auto update. We have an SP540V and had the same issues with VW. Wife got it to work, but we were told by our tech that the updates are not for our printer. They are "blanket" updates covering the whole spectrum of Roland products and can cause issues.
  5. I only used the update after reinstalling.
    Frustrating to say the least.
    Seems to happen the most when I'm in a rush.
    It's kinda like breaking a shoe lace when your in a hurry to
    go somewhere.
  6. Colin
    Colin Major Contributor
    4,514
    15
    38
    Sep 16, 2004
    Earth
    It's a shot in the dark, but have you got the latest firmware update for the printer? Wondering if there might some sort of disconnect there.
  7. ova
    ova Member
    437
    1
    18
    Dec 22, 2008
    Wheeling, WV
    Welcome to the party. Be sure and have them send the report to the cyber space police.
    Dave
  8. duggan
    duggan Member
    35
    Very Frustrating
    Glad to know that I'm not the only one with this issue!
    I didn't know if maybe I needed a better computer or what!
    Are there any other options/Rip programs that would work with my Roland XC540? Just curious!
  9. DigitalPrintTech
    DigitalPrintTech New Member
    20
    Jul 3, 2012
    Whitewright, TX
    What version of VW are you running?
    What OS is VW running on?
    If your system is low on virtual memory, you will have this problem.
    Also if there is a stack of completed jobs in the print queue that will cause the program to freeze up like crazy.
    To many background programs, can use needed memory which kills VW. Need to be running a minimum of 4 Gigs of RAM. I know the minimum required amount is only 2, but raw files are small, but once they rip and print, they grow in size, and use needed memory if there is too many in the queue.
    Notice: There is a pattern to my post.
  10. mudmedia
    mudmedia Active Member
    507
    had our versaworks on just a old windows xp 1 gig of ram nothing special pc had freezing issues and funny like you said its always when your in a rush lol exactly how I felt. I then upgraded our design pcs and moved one of them as a ripping station the machine had 6 gigs of ram and a decent processor obviously the computer specs made the pc run better but that solved our freezing issues..Its unfortunate that doing it that way cost money probably when it shouldnt be like that but just letting you know that improving our pc for ripping helped.
  11. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    Used to happen to me all the time. Since my computer upgrade, it has only happened once. I still don't know what causes it, it just happens, no matter how fast or loaded your computer is. Just in case, go into your anti virus software and make sure you put versaworks.exe on the excluded list. Why waste resources scanning RIP files/processes which can be up to 2gb big?
  12. samgrafix
    samgrafix New Member
    2
    I too am running an XC-540 with VW on XP and have issues with VW locking up. I do keep jobs in my queue. I'll have to see if that solves the problem. Sometimes I'll go a week with no issues and lots of jobs in the queue. Many times it will lock up when I have very few in the queue.
  13. anotherdog
    anotherdog Very Active Member
    1,191
    Happened to me with my VP540, just a particular update would not allow jobs to RIP. I ran an older version for a couple of months with no problem, tried the occasional update until the problem went away. This was on two system 7 machines, a Vista and an XP.
    Most of the updates give the older machines no benefit. They are for the newer machines.
