PHOTO GALORE
hello guys , need ur help.
i have vinyl express qe 60 with lxi 8 and flexi 7.5 v2 .
the cutting results are unsatisfactory. i am new to all this never used a vinyl machine before.
so,
here it is.
which blade is used for cutting oracal 631.(how thick is it)
what are the pressure, offset and speed settings
if any 1 else has the same scenario.
I am using 0.9 mm blade with spring...
pressing the test button creates the arrow in a square box. the lines of the square box are not straight even the arrow looks croocked..
playing around with pressure etc.
three corners are better but one corner looks rounded.if i increase the length of blade the rounded corner become Croocked. ( the lines are not straight.)
i might be using the wrong blade or something.
( i am totally new)
if i decrease the pressure to real low value. the test results are better .but it wont cut deep enough.
please help me to improve the cutting test results.
what should i do ..
thanks for you help and time in advance.
thanks for allowing me to be the member of this great forum.
so,
here it is.
( i am totally new)
what should i do ..
