I'm probably being stupid here.  Normally when I load my graphtec with vinyl it goes thru the normal procedure of indicating the vinyl and then stops at the origin to begin cutting.  Now, it goes thru the same procedure but then starts feeding the vinyl thru, and doesn't seem to want to stop.  I need to turn off the plotter to get it to stop.  Thought it was a setting that got messed up but I can't even get into the menu to look at anything.  I don't use this a ton, so I apologize if this is a no-brainer fix, but can someone help me out?
