Vinyl Master Pro
Discussion in 'New Member Introductions' started by Silverado, Aug 17, 2006.
  1. Silverado
    Silverado Member
    86
    I'am considering purchasing Vinyl Master Pro as a less expensive software alternative to FlexiExpert.
    Any thoughts?
    Thanks... Roger
  2. pmoney
    pmoney New Member
    20
    You might also try CiberCut Max. It is a very good program for just under $500.00. Click HERE.
  3. Whit
    Whit Member
    295
    It has it's advantages/disadvantages !!!
    Pretty much,,, what you're comfortable with !!!
    Got both here,,, use each in certain areas !!!
    Only problem here is on daylight savings change,,,
    seems it knocks it off till reregistered !!!
    Mines the older version,,, no key,,, just #'s !!!
  4. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    corel draw and cocut pro would be my choice,,, For one reason is resale value if anything.
    VMP seems to be asleep. Every now and then they announce the soon comming version 3,, but then they fall asleep again..
  5. Silverado
    Silverado Member
    86
    Hi Techman... Do you have any experience with VMP?
  6. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    i tried it,,, liked it,, but love corel draw / cocut pro more,,,
  7. Pro Signs & Graphix
    Pro Signs & Graphix Very Active Member
    2,477
    We have to agree with Tech on this one. If you are looking for an alternative, Corel and CoCut would be a very viable way to go. The makers of CoCut will bend over backwards for you.
    You may also be able to cut directly from Corel - if you are still using a Roland.
