Vinyl Master running a Vision engraver
juan45215
Just bought a used Vision 1212. I'm running VMP for vinyl cutting. VMP list the Vision 1212 as a compatible cutter.
Has anyone seen VMP run an engraver?
Techman
dont know about your machine setup. But, my anagraph cutter can engrave. So, I would guess that it will work.. It's the same principle./
V-ENGRAVE
I would guess your VMP will generate outline of the font that can cut by Vision engraver. If can also generate hatch fill lines make sure it starts from center out. Engarving fonts are specifically designed for optimal tool path.
