Vinyl Stencil Window Painting.
Discussion in 'Hand Made Signs' started by Jwalk, Apr 12, 2017.
  1. Jwalk
    Jwalk Member
    328
    5
    18
    May 27, 2014
    Toronto
    I use vinyl mac tac for window painting.
    I have used aura benjamin moore, and one shot. Both paints will peel up with the stencil, most of the time I put more than one coat and do not peel it wet.
    On the more complicated stencils one where I can't peel away from the letter I have to use an exacto and literally cut out the letter from the stencil, before I peel off the stencil.
    Looking for different approaches and or ideas. Thank you.
  2. Stella_FB700
    Stella_FB700 Member
    74
    14
    8
    Jan 30, 2017
    Canada
    Use paint mask vinyl - it works wonders.
  3. Billct2
    Billct2 Major Contributor
    7,463
    642
    113
    Mar 12, 2005
    New England
    Yes, try real paint mask and try to get it in one coat of oil based enamel and peel while tacky
    • I Appreciate You I Appreciate You x 1
  4. OldPaint
    OldPaint Major Contributor
    OR DO IT LIKE US OLD GUYS DID...... FREEHAND.......no mask needed)))
    • Agree Agree x 2
  5. Jwalk
    Jwalk Member
    328
    5
    18
    May 27, 2014
    Toronto
    Sorry I meant paint mask vinyl.
    I dont see much difference in 5yr vs paint mask in the peeling/stencil aspect, big diff in tackiness from the glue but that's it.
    Yeah I figured thats the answers I'd get. You know theres an art in cutting it out I use one of the artist style exacto's. Oh well.
  6. studio 440
    studio 440 Member
    373
    50
    28
    Jul 19, 2010
    cali
    gerber maskis great
  7. visual800
    visual800 Very Active Member
    3,919
    264
    83
    Aug 4, 2010
    montgomery, alabama
    for paint stencils we use cheap vinyl as it costs less than stencil vinyl. Also keep in mind before you paint the actual stencil take exacto and cut a line between each letter so you can rip off just that one letter at a time if need be
    ALWAYS peel it wet especially with latex and use foam rollers, foam rollers lay on a good level coat.
    May I ask what you are painting on these windows
  8. OldPaint
    ONLY WAY FOR PAINT NOT TO PEEL when removing mask...........YOU WILL NEED TO TAKE EXACTO to all edges where the paint meets the mask.
    1. GLASS IS A NON-POROUS SURFACE.......
    2. THE VINYL IS MORE POROUS then the glass.......
    3. pulling the vinyl...........WITHOUT CUTTING THE PAINT........WILL PEEL THE PAINT OFF THE GLASS.
    • Like Like x 1
  9. Billct2
    7,463
    642
    113
    Mar 12, 2005
    New England
    ...unless you peel it while it's still wet, which is what everyone has suggested.
    • Like Like x 2
  10. Jwalk
    Jwalk Member
    328
    5
    18
    May 27, 2014
    Toronto
    Yeah I know believe me cutting big time.
    what im putting on the window is like this but a different store front.
    A Nerd’s World
    I wish the vinyl stencil worked like frog tape or blue tape. On windows I find the good painters tape works good.
    I use the normal vinyl for most of my stencils but some I use the paint mask mac tac. I use paint mask for drywall and window type thing.
    Ill check out the Gerber mask
  11. Billct2
    7,463
    642
    113
    Mar 12, 2005
    New England
    OK, that makes a difference, definitely trying trying to mimic a window splash painter, but since its' not the real thing, why not reverse printed vinyl?
    • Like Like x 2
  12. visual800
    3,919
    264
    83
    Aug 4, 2010
    montgomery, alabama
    just do vinyl on it. I would waste my time painting all that
  13. Jwalk
    Jwalk Member
    328
    5
    18
    May 27, 2014
    Toronto
    Yeah thats what I do reverse stencil, paint mask, when you have to cut it out its almost like painting the outline.
  14. Johnny Best
    Johnny Best Very Active Member
    3,431
    1,921
    113
    Dec 9, 2015
    buffalo ny
    So on the word "world" on the glass, you mask out that thin inline, let it dry then paint orange, let that dry, then the dark maroon dropshade, letting each color dry before the next color is applied.
    I agree with visual800 on this one. Use vinyl and or reverse print it on clear and make it double sided.
  15. Jwalk
    Jwalk Member
    328
    5
    18
    May 27, 2014
    Toronto
    yeah, that's what I do, I've done 9 windows like this already. 3 more at the new location.
  16. Johnny Best
    3,431
    1,921
    113
    Dec 9, 2015
    buffalo ny
    Well, I have to hand it to you, they look great and good luck finding the solution to your problem.
    I agree with others, Gerber mask and foam roller, and peel off while tacky using your exacto blade to get it started.
  17. Signsfyi
    Signsfyi New Member
    20
    4
    3
    Nov 18, 2013
    Durango, Colorado
    When I have painted on glass using a stencil, I scrub the area of the glass with Bonami. Then do a final wipe with rubbing alcohol. Roll with a foam brush and I prefer to pull the stencil while the paint is wet.
    However, in this day and age, I would either do printed on clear vinyl in reverse or do layers of cut vinyl. Sample looks great! Good luck.
  18. The Yanki & The Brit
    The Yanki & The Brit The Yanki & The Brit Signs and Radio Show
    231
    62
    28
    Sep 3, 2014
    Texas
    That's what I was going to say! Without the old guys part! LOL....
  19. Gino
    Gino Premium Subscriber
    33,331
    2,328
    113
    Jun 7, 2006
    PA
    Okay, so you don't do murals the traditional way, you use stencils. The way that's set up you only need two friskets. Paint on the inline and use a brush, not a roller. That's why you need two and three coats. When you're finished with the inline, peel it back and wait for it to dry. Now paint in the orange, peel it and let it dry. Now, go back and use scotch tape for your shadows and freehand for the curve parts.
    For the white stuff, paint it in and pull it off as soon as you're finished and let dry. Now, paint i your outline and peel off when done.
    Now, it's up to you, but back paint everything with one solid uniform color so your yuxes don't show up from the inside or put a full vinyl cover on the inside of the window.
    You've been flaunting your wares around here long enough, that you should be able to do this freehand, but if not, you should at least be able to fill in the simple parts by hand.
    The two windows and door you have shown would take maybe 2 days, mostly because of dry time.
    Instead of double coating..... don't take the paint directly out of the can and put it on the window. Use some other colors that will stiffen your colors so it will cover in 1-Shot as the name implies. Again, don't do this with rollers, you can't get good coverage unless you slop it on.
  20. Johnny Best
    3,431
    1,921
    113
    Dec 9, 2015
    buffalo ny
    Hey, where is OldPaint, have not seen or heard from him in awhile, I miss his insight.
