VJ-1604 card issues
Discussion in 'Mutoh' started by PhatWall, Oct 8, 2012.
  1. PhatWall
    PhatWall Member
    82
    I have a mutoh vj-1604 and i just got done printing a banner. I switched material abd when i put down the blue load lever the material would not initialize the size. It just said initializing so I switched of the power and rebooted the printer and have a new problem. First of all I use 3rd party ink which require cards. Anyways back to my problem the machine wont read the cards at all now. It does read that I am inserting a carterage but it says KCMY not original no matter how many cards I try!!! I have even tried several firmwares!!!
  2. signworldusinc
    signworldusinc Merchant Member
    507
    3
    18
    May 16, 2012
    Rancho Cucamonga, CA
    This problem occurs sometimes when you are switching/upgrading firmware. Most firmware updates prevent the use of 3rd party ink cartridges thus rendering your cards useless.
    Regards,
    Signworld Team
  3. PhatWall
    PhatWall Member
    82
    fw
    i am running 1.13 and was working fine before.
  4. heyskull
    heyskull Very Active Member
    1,668
    15
    38
    Sep 2, 2007
    UK
    i would contact your ink/card supplier and see what they can do.
    I stupidly upgraded the firmware on mine from 1.09 to 2.00 and that created the same problem you have.
    I was told you now couldn't run third party inks on it but I have now installed a bulk ink system which runs great using jetbest inks.
    Are you running cartridges or bulk ink system?
    SC
