Hey mvp-graphics,
Tizz is right, static can be a significant contributor to deflection and over-spray, along with a possible encoder scale/sensor issue. Based on the description provided, we're thinking static.
We’ve even published a static bulletin available for viewing here:
http://support.rolanddga.com/docs/d...es/static suppression for roland printers.pdf (Don't forget to check other causes, such as humidity around the printer, not just the room temp).
You'll have to verify the environmental conditions for the printer. It's recommended to take at meter that can measure the humidity “at” the printer. If it's out of operating range, then adjust the room environment to get the humidity to an acceptable range (the values are found in the specifications section of the user manual).
Ultimately if the problem(s) continue, please submit an "official" Roland support request form online here:
Product Support Form | Roland
If you do write us, we look forward to helping you and take care,
Roland Technical Support
Roland DGA Corp.
rn
