VP 540i special banding
Discussion in 'Roland' started by romichoux, Jun 11, 2012.
  1. romichoux
    romichoux Member
    37
    Hello guys,
    I'm french and I need some help about banding. I don't know if it's the correct word
    I have banding on a VP 540i.
    This kind of banding looks like a lighter band and this phenomenous is completely hazardous. sometimes that's happening just after several inch (about 10). see the attached scheme
    This what I have checked:
    - feed motor calibration (service menu)
    - pinchroll pressure
    - take up motor tension.
    - encoder strip and calibration (service menu)
    - capping and pump. I swapped the 2 pumps
    - swap head cables
    - swap printheads and print 100% of each colors
    - create a new profile ICC
    I will check dampers also but their don't look like damage.
    do you have an idea? do you know this problem?
    thanks in advance!
    Romain
    http://www.imagup.com/data/1154107109.html
  2. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,847
    70
    48
    Feb 27, 2007
    World
    Post a picture
  3. CanuckSigns
    CanuckSigns Very Active Member
    3,431
    397
    83
    Nov 11, 2008
    Ontario
    Bonjour!
    we have this issue sometimes on our machine, is the printer is a controlled environment (humidity, temperature)?
    if you are in a bind and need to get a job out the door, I have run in uni-directional high quality before and it goes away, but it's painfully slow!
  4. romichoux
    romichoux Member
    37
  5. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
  6. romichoux
    romichoux Member
    37
    Bonjour ;O)
    Thanks for your help and your advices...!!!!!!!!!!
    I will try to find a solution with that
    Romain
