VP 540i special banding
romichoux
Hello guys,
I'm french and I need some help about banding. I don't know if it's the correct word
I have banding on a VP 540i.
This kind of banding looks like a lighter band and this phenomenous is completely hazardous. sometimes that's happening just after several inch (about 10). see the attached scheme
This what I have checked:
- feed motor calibration (service menu)
- pinchroll pressure
- take up motor tension.
- encoder strip and calibration (service menu)
- capping and pump. I swapped the 2 pumps
- swap head cables
- swap printheads and print 100% of each colors
- create a new profile ICC
I will check dampers also but their don't look like damage.
do you have an idea? do you know this problem?
thanks in advance!
Romain
http://www.imagup.com/data/1154107109.html
CanuckSigns
Bonjour!
we have this issue sometimes on our machine, is the printer is a controlled environment (humidity, temperature)?
if you are in a bind and need to get a job out the door, I have run in uni-directional high quality before and it goes away, but it's painfully slow!
