weird banding in white area
bigben
Not a newbie
I have an HP L26500, using a new synthetic paper and have created my own profile. For some reason if I print something with heavy covering beside a white part. I will have fine banding in the white part where there supposed to have no ink. It's not very noticable, but I can wipe the banding with my finger.
Here is the best picture I could take. You can barely see it, but it is more noticeable in person. I've never experienced this before. What could be the problem and solution?
DerbyCitySignGuy
So when you print pure white next to a block of color, for instance, the white has a slight hue to it the first few passes?
Could be a static/overspray issue? Some of the CMYK inks getting on the white heads and creating a slight off color for the first few passes. That would be my best guess.
bigben
Not a newbie
This is exactly what happen and is exactly what I suspect (static/overspray). How can I manage this?
DerbyCitySignGuy
I know you said it's paper, but can you treat the area with an anti-static spray before printing (easier said than done on a roll to roll machine)?
Short of keeping your print room at 70 degrees and 50% humidity, I've never found a perfect way to deal with static.
I don't think it's overspray. If it looks like banding my guess would be optimizer. Optimizer is clear but certain substrates you can see it. Also if you have a vector that is colored white there is a lot of times where the HP will lay down optimizer but no color. My guess is you have a banding issue with your optimizer head and you can see it in the blank areas.
bigben
Not a newbie
With the winter right now, it's very dry in the shop. This is why I think it is a static problem. I've just printed the same thing to a regular vinyl and there was no problem at all.
I can't be the optimiser. My latex model (L26500) don't have the optimizer.
