Weird illustrator problem
Discussion in 'Adobe' started by petepaz, Aug 10, 2009.
  1. petepaz
    petepaz Major Contributor
    4,333
    81
    48
    Feb 14, 2007
    NJ/NY/PA
    Weird illustrator problem<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    This is a new one never saw this before<o:p></o:p>
    Running cs (it’s one of the older computers and haven’t updated it yet it’s next on the list especially since the last couple of updates you can only get 2 down loads per disk)<o:p></o:p>
    Anyway when ever I open a file I can not move the artwork<o:p></o:p>
    It will let me click/select the item by no movement allowed<o:p></o:p>
    Nothing is showing up locked and when I try to move using the arrow keys I get a message <o:p></o:p>
    Can not perform this action and it crashes <o:p></o:p>
    Everything else on the computer seems to be working ok<o:p></o:p>
    I guess I will try to re-install and see what happens <o:p></o:p>
    But if anyone has had this or a similar problem and can shed some light <o:p></o:p>
    It would really be appreciated <o:p></o:p>
  2. HaroldDesign
    HaroldDesign Very Active Member
    1,367
    I would start with emptying your caches. I've had some odd problems once in a while, and a lot of times this did the trick.
  3. beermonster
    beermonster Member
    72
    had this too
    trash the prefs and reboot - no need for fresh install - thats a route taken too soon/easily
    if the file is a legacy file you may need to use the expand feature, and expand strokes and fills
