PH chip has to be replaced with the blank one and programmed, that's it )))What has to be done to use the 831 head on the 25500?
Are these HP or another companies, Who can I contact?We now running two of 25500 and two 26500 with the bulk system installed. 831 heads, 891 inks in the bulk system.
There are also some other way to go around and over the discontinued inks production issue.
You can contact me directly.Are these HP or another companies, Who can I contact?
Yes, they're intended to be partied with Opt but still work fine on the older machines after some easy trick been applied.Don't the later HP inks use some sort of Optimizer solution which I assume the 26500 would not have?
We do refurbish and repair them in-house.What about cleaning kits and any other parts that might break?
Sorry I am not sure how to contact directly within Signs101, if you can send me a email address or phone to graphics@communityprinters.com I will be contacting you. Thanks, Ken GrahamYou can contact me directly.
Sorry but on our third HP...and with all that has to do with these machines.(way to much to discuss...if you have one you know)..humm..this is our last HP printer...
Oh I should say the machine prints great when you baby sit it...just all that incumpuses the machine is ridiculous...from loading media,, recognizing media, warm up, then print...omg....extreme amount of time...and lord forbid if you don't run out 3 feet of material to get it started, look for a media strike to happen...Which model is giving you problems?
(I'm still nurturing out L260 till I use up the 25 ink cartridges I have - and I like the machine.)
