What cutter??????
Discussion in 'Newbie Forum' started by Jag, Aug 15, 2006.
  1. Jag
    Jag New Member
    10
    Hey people,
    I stumbled onto this forum, great info.
    Im looking to cut vinyl lettering 3" x 10", such as "Forum Newbie". I will need to cut about 100 of these sentences a day. I will not be cutting graphics or anything much larger than that. I thought about getting a Roland 24" cutter. Am I going overboard? Could I get away with the 15"? Another vendor to save money? Is this 21 questions???
    Seriously, I would like to keep expenses down but I don't want to buy an underpowered etc. cutter.
    Thanks for your help!!!
    Jag
  2. gerald
    gerald Member
    405
    Is this all you'll ever cut? Do you plan on expanding? How important is ease of weeding to you?
  3. Pro Signs & Graphix
    Pro Signs & Graphix Very Active Member
    2,477
    A 24" cutter will be your best choice and value. A 15" will work but you are limiting yourself - which is not worth the savings you may realize. Whatever you do, stick with a proven brand, such as Roland, Graphtec, Ioline, etc.
  4. Jag
    Jag New Member
    10
    Expanding
    I will not need to expand. The text will remain the same and the size will not change. I take it weeding is pulling pulling off excess vinyl????? I guess I just tilted my habd and let everyone know I've never done this before.....
  5. Jag
    Jag New Member
    10
    I have not heard of Graphtec or Ioline. I will check them out.
  6. Pro Image
    Pro Image Major Contributor
    4,550
    Nov 28, 2005
  7. Jag
    Jag New Member
    10
    Thanks! Im checking it out. Its says its designtec. Is that like a Chevy and GMC thing?
  8. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    if that is all you wish to do,, outsourcing may be a better choice,,,,
  9. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Just out of plain freaking curiosity... what kind of stuff are you thinking of making???? 100 sentences a day? WTH? That makes no sense unless you work for a bunch of the states hospitals or something.??? Just kinda curious here...
    24" will be easier on you IMO. I'm a Graphtec fan myself. Check 'em out. Stay away from plotters named after animals...
  10. Jag
    Jag New Member
    10
    License plate frames. Advertising for my business. I cant have them made in bulk as the sentance will change slightly.
  11. Jag
    Jag New Member
    10
    LMAO, I just went to sign warehouse and was about to search on thier cougar, lynx and panther product.......
  12. Pro Image
    4,550
    Nov 28, 2005
    Yep its a renamed "HOUSE" brand...........same thing as the ce3000 series.......
  13. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    get a NAME brand..
    suma, graphtec, roland,,
    do not get a cheap one.. or you will be very sad someday..
  14. Cadmn
    Cadmn Very Active Member
    2,859
    repeat NO ANIMALS you'll be sorry 3" 10" license plate frame ? I could cut & send u unweeded.
  15. Jackpine
    Jackpine Major Contributor
    SSK has a great deal on a DesignTech, a renamed Graphtec cutter 799.00 and free shipping...........or a CE3000Mk2 24"
    They have great tech support.......second to none!
    www.signsupplystore.com
  16. Chino
    Chino New Member
    6
    dont think small man, at least get a 24" if you treated well it can be any brand this is your choice, all depends in your budget hope you made a wise decision Good Luck.
  17. learned the hard way
    learned the hard way Active Member
    544
    A 24" cutter will not be overkill. If you turn your 3" graphic sideways for cutting you can fit about 7 in a row, leaving very little waste.
    However, if you plan to cut, weed, premask and stick 100 of these a day... you're not gonna have much time to run your business. If you don't plan to do anything else with the cutter, I think you would be better off to settle on 2 or 3 different phrases and have a few hundred at a time screenprinted....leaving your time free to run your business.
  18. Jag
    Jag New Member
    10
    you guys are great. Im going with the Graphtec CE3000-60 24".
    Thanks for your help,
    Jag
  19. Jackpine
    Good choice....SSK has bundles with clip art and cutting software.
  20. SignPainter
    SignPainter Member
    52
    Ioline! nuff said
