I am going nuts!!!! It seems everyday I am throwing profits out the door in wasted material while spending hours trying to figure out how to get things to work right. Never had issues for the last 10+ years until using Cloud. I had major issues on one computer/machine after upgrading to Cloud that I finally (kinda sorta) got straightened out last week. But now on my other computer it has become a nightmare. This computer/printer has been working fine with Cloud for the last 6 months and now after what appears to be an update with Flexi all hell has broken loose.
Now after I laminate, the machine (Roland SP-300V) finds the crop marks and starts to cut but it is off by about half an inch on all cuts down the length of the roll. The first row of cuts isn't even complete because those cuts would be in front of the crop marks. Left to right cutting is right on. I've tried restarting production manager, restarting the software, restarting the computer, tried different files all with the exact same results. It still prints/cuts fine if I send the job at as one. This all started after what appears to be a software update since my production manager looks different now.
Everyone else just having a blast with the Cloud version?
Update/More info since I've been playing around with things for several more hours with still no solution:
For this set up I am running a Roland SP-300V with 11sp6 Build 2145 on Windows 8.1.
- When I print, laminate and put the material back in the machine the crop marks are found properly. But when it goes to cut, the cuts are precisely 0.5 inch off down the roll. It wants to cut a half an inch towards the front of the sheet. I've tried different files, resetting the computer, etc. with the same results. Machine cuts just fine if I send as one job so this only has to do with production manager/crop marks.
- Since I have to wait 24 hours for the ink to dry so I can laminate/re-cut I decided to do some test prints using crop marks and then instantly try to do the cut. This is where it even gets more weird. At first I did two small blocks a few inches apart but on the same plane. When it cuts it wouldn't cut the line closest to the front of the sheet. It would just cut a U shape instead of the entire square. When zooming in within PM it appears that that front side cut is missing for some reason even though it shows just fine in the design software.
- So I decided to do a different test cut with the boxes off-set having one down the roll a few inches. Not surprisingly the front line didn't get cut as in tests beforehand. But what is even more odd is that the square that was further down the sheet actually cut sides next to the square but the cut was elongated by about 0.25 inches. It essentially made a 1.00 square into a 1.0x1.25 inch cut. So it isn't anywhere close to the printed square on the end closest to the front of the sheet.
